Centerline Issues for Turning Inserts
Tooling experts Mike Fagan and David Grant suspect that many programmers and machinists could use a refresher on the importance and effects of insert alignment in turning operations. This short, amply-illustrated paper is their effort to clear up some of the misunderstanding.
Photos of sample inserts such as this one illustrate wear patterns that help diagnose cutting tool misalignments in turning.
Tooling expert Mike Fagan suspects that many programmers and machinists could use a refresher on the importance and effects of insert alignment in turning operations. This short, amply-illustrated paper is his effort to clear up some of the misunderstanding.
It covers signs of misalignment and suggests ways to fix problems, with additional tips and advice to improve turning operations. To find the paper, click here.
10 Tips for Titanium
