Doubling Down on Setup Reduction
Angle heads still find plenty of use for reducing setups, even in shops using sophisticated multi-axis machine tools.
Despite a long history of helping manufacturers reduce setups, the angle head might seem like little more than a relic in an era characterized by increasingly sophisticated multi-axis machine tools. According to Big Kaiser Precision Tooling, however, that’s not the case at all. In fact, manufacturers are finding that this tried-and-true can help double-down on the setup-reducing capabilities of four- and five-axis machines, particularly in the aerospace and energy industries. That said, they do come with inherent limitations that any potential user should keep in mind. Learn more here.
Jergens Pull Studs Enable Quick Changeovers
SP140 and K02 pull studs offer quick-change solutions for vise or gripper jaws, electronic component manufacturing, packaging machines, medical technology and automation.
Big Daishowa Chuck Eliminates Chatter in Milling Operations
The Mega 12DS chuck is designed for trochoidal milling with anti-vibration end mills.
