Ensuring Accuracy by Containing Coolant
One of the details that has been improved on a new cylindrical grinder is a casting design that isolates coolant from affecting the structure of the machine.
The word “coolant” is deceptive. Coolant in machining is a heat-transfer device. While the fluid cools the cut by transporting heat away from the work zone, it carries that heat to wherever the coolant then lands.
Toyoda says it engineered its new GE4-i cylindrical grinder in part with attention to the thermal effects that might come from heat transfer via coolant. The machine is seen here at this year’s IMTS, where it debuted. The company says the machine’s redesigned casting contributes to thermal stability by capturing and channeling the coolant that falls from the workzone in order to isolate it from the structure of the machine.
Another feature of the GE4-i is an icon-driven and user-friendly control interface, which is valuable in part as manufacturers adapt to the difficulty of finding skilled labor in grinding. More on that here.
Hennig Inc. Acquires Industrial Coolant Systems
ICS develops and field tests high-pressure coolant systems, coolant filtration systems and other machine tool solutions.
Managing Coolant with Skimmers, Refractometers and More
Bacteria-infected coolant harms machines and sickens machinists. Coolant management technologies like skimmers and automated systems counter this tendency.
Unist's Electronic Control Regulates Lubricant Delivery
Unist’s Pulse R electronic control ties into the system control solenoid valve and takes the place of a pneumatic pulse generator timer or logic block.
