Five-Axis Machining Complements Additive Manufacturing
Intricate components made through laser melting go directly to a five-axis machine as part of a service combining additive and subtractive processing.
What machining capability is the right complement to additive manufacturing? For Star Prototype, the answer is a UMC-750 five-axis vertical machining center from Haas Automation (seen here when it was newly purchased in June 2015) programmed using Delcam’s PowerMill software.
The British-owned company based in Guandong Province, China, combines metal 3D printing and five-axis machining to quickly deliver complex, low-volume components that might previously have required the work of two separate suppliers. It calls this service AddSub Manufacturing.
“Many metal 3D printed parts are no longer used as prototypes but as complex low-volume manufactured components,” says Gordon Styles, president of Star Prototype. “As a result, many of these parts need certain high-precision features that are virtually impossible to produce with 3D printing alone.”
The company uses a Renishaw AM250 direct metal laser melting machine to produce dense, complex metal parts in titanium, stainless steel and aluminium. The challenge of machining those parts is not the amount of stock to remove, because the parts are so near to net shape. The machining challenge instead comes from the geometric complexity that additive permits, which led to the five-axis machine purchase. (Indeed, the connection between complex machining and additive manufacturing is a point Delcam recently highlighted in a test case with additive production.)
Star uses five-axis machining to add features to additive parts such as mating faces, precision bores and tapped holes. Whenever possible, the company says, parts are built on the AM250 in a useful orientation for machining, with supports designed so that the build plate can be transferred directly to the five-axis machine.
Heavy Engineering: The Complex Logistics of Moving Large Machine Tools
One of our fascinations with large-format machine tools has little to do with their capabilities, but everything to do with the logistics involved with getting them up and running. Here’s how one of the world’s oldest builders of giant machine tools tackles the challenge.
