Get the Handbook on MQL
A free handbook from Unist explains the benefits of minimum quantity lubrication and offers advice for those interested in moving away from conventional flood coolants.
Minimum quantity lubrication (MQL) is used more in Europe than here in the States due to stricter environmental regulations across the pond. However, MQL has a proven track record in working just as well as, or better than, traditional flood coolants for certain applications. Plus, shops don’t have to deal with negative consequences like health hazards, disposal costs and pricey circulation equipment. If you’re interested in learning more about MQL, consider signing up to receive the “MQL Handbook” offered by Unist, the Grand Rapids, Michigan manufacturer of MQL systems for metalworking applications.
The handbook explains how MQL differs from conventional coolant methods, how it works, what equipment is needed, how to develop an MQL process and what fluids work best for it. Sign up to receive the handbook here.
Jorgensen's Coolant Collection System Eliminates Sludge Build-Up
The PermaClean system adds agitation to the coolant collection system or holding tank and prevents particulates from settling.
Master Fluid Solutions Semisynthetic Coolant Inhibits Corrosion
Trim MicroSol 685XT is designed to provide enhanced corrosion inhibition on all ferrous and nonferrous metals.
AFT's Semi-Synthetic Coolant Extends Sump Life
Advanced Cool 2200 provides high visibility while machining, keeping the machine and parts clean with no odor issues.
