How Important Is Oil Filtration for Grinding?
Oil filtration is pretty important for grinding, especially when you’re trying to “dust” a few microns off a part.
The 250-gallon centrifuge filtration system for this external thread grinding machine removes swarf as small as 5 microns from the full-synthetic oil coolant the machine uses.
B&R Grinding, located just south of Chicago’s O’Hare airport, specializes in precision thread grinding. Its latest CNC external thread grinder, a GS:TE 200 unit from Drake Manufacturing, offers a 1-meter grind length and180-degree grinding wheel power helix. This machine enables the shop to accommodate the longer, higher-helix-angle thread grinding work its customers are asking it to perform.
Another important component of this machine is its 250-gallon centrifuge filtration system that removes swarf as small as 5 microns from the oil. That prevents the swarf from being introduced between the wheel and the workpiece, which could create scratches. It also cools the oil to a consistent 70°F, and some of it is delivered through the machine’s headstock to prevent spindle expansion during grinding operations.
Learn more about how the shop leverages this machine capability and others in this article.
Five-Axis Changes Weldments Into Monolithic One-Piece Parts
Moving from welding to five-axis machining enabled Barbco to redesign its weldments as monolithic one-piece parts with improved strength and repeatability.
Dielectric Oil Dramatically Reduces EDM Maintenance
Plagued by repeated small fires that interrupted its wire EDM throughput, this cutting tool manufacturer changed its dielectric oil and both eliminated fires and reduced its oil consumption.
4-way Bed Precision Lathe Features Automated Cycles
Long and thin workpieces can be machined without reclamping on this new machine from Weiler, according to the company.
