Making Tooling More Cost Effective
Something as simple as trading standard retention knobs for a longer version could help eliminate bulge in V-flange tooling and the problems associated with it.
Hansen Engineering Co. used a standard retention knob in the toolholder on the left. Taper deformation prevents the toolholder from properly mating with the CNC machine’s spindle, however. In contrast, the photo on the right shows use of JM Performance Products’ high-torque retention knobs in the toolholder. A longer design enables the knob to reach deeper into the holder’s threaded bore, improving taper-contact quality.
When a standard retention knob is installed in a V-flange toolholder, pressure exerted by thread engagement, coupled with the elastic properties of the steel used to manufacture the toolholdrers, creates a bulge at the small end of the holder. Once expansion occurs, the holder will not pull all the way into the spindle, and the toolholder cannot make contact with upwards of 70 percent of the spindle surface. When this happens, vibration, chatter, poor tolerances, non-repeatability, poor finishes and shortened tool life are among some of the problems that shops can face.
Hansen Engineering Co. knows these problems all too well, as its everyday machining operations began to present increased issues. A simple solution that reportedly increased the aerospace engineering shop’s productivity by 15 percent and decreased downtime was a high-torque retention knob from JM Performance Products Inc. The high-torque knobs are longer and reach deeper into the holder’s threaded bore than standard knobs, which encourages thread engagement to occur in a region of the toolholder where there is a thicker cross section of material to resist deformation.
Big Daishowa Chuck Eliminates Chatter in Milling Operations
The Mega 12DS chuck is designed for trochoidal milling with anti-vibration end mills.
Five Common Mistakes Shops Make with ER Collets (And How to Prevent Them)
Collets play a crucial role in the machining process, so proper tool assembly and maintenance is important. Here are five potential pitfalls to avoid when using ER collets.
