Blog
27. February 2013
Plating Q&A: Low Stress Nickel Deposit
Question: We receive parts that specify a “low stress” nickel deposit. Are there numerical ranges for high- and low- stress nickel deposits? D. M.
Answer: I am not aware of any standard that specifies numeric values for high and low stress deposits. Perhaps one of our readers can enlighten us on this. That said, let's talk about stress in nickel deposits. Residual stress in nickel deposits is affected by the plating bath composition. The table below shows some stress values.
Solution Anion
Residual Stress (psi)
Sulfamate 8,600
Sulfate 23,100
Chloride 33,000
Typically, sulfamate nickel is called for when a low-stress deposit is specified. The conventional Watts nickel bath, which contains sulfate and chloride, gives a deposit with a high-residual stress. Adding stress reducing agents to the plating bath can reduce this stress. In some cases, this is satisfactory but if an additive-free deposit is required, you will have to think in terms of the sulfamate plating bath.
Other factors will influence the residual stress of the deposit like temperature of the plating bath and the actual substrate itself.
A much more detailed discussion of stress and plated deposits can be found in the book, Electrodeposition – The Materials Science of Coatings and Substrates by Jack Dini. The book is available from Metal Finishing Publications, (212) 633-3199.
To read more answers by Art Kushner, please click here
Nov. 18 – 20 |
Las Vegas
Request your eXecutive Guest Invitation NOW!
Download
The Ultimate Shop Management Software Buyer’s Kit Free from JobBOSS
Subscribe to these Related
RSS Blog Feeds
