Try 110
First, recall this scene in the movie "This is Spinal Tap" where Brit guitarist Nigel Tufnel deftly explains the value of having amps with knobs that go to 11 (versus most blokes’ amps that only go to 10). Now, consider the following machining tip as you replay that “one louder” scene in your mind: Turn the feed rate override to 110 percent.
Steve Paulding, a cutting tool specialist for the Industrial Distribution Group, suggested the strategy in response to this column I wrote about how potential gains in productivity often go unrealized. Mr. Paulding says increasing the override to 110 percent oftentimes will reduce milling or turning cycle times by 10 percent and improve tool life. He believes 6 seconds can be cut from every 60 seconds of cycle time, and 30 minutes of tool life can be extended to 31.5 minutes.
Mr. Paulding recommends running with the override at 110 percent for a little while. If no part-quality or tool-life issues arise, edit the part program with the higher feed rate and drop the override back to 100 percent. If all continues to go well, bump the override up to 110 percent again and see if you achieve additional gains. By continuing this process until a problem arises, Mr. Paulding says you’ll know how far you can push your tools and machines.
I admit the "Spinal Tap" analogy is a stretch and tad silly, but being a guitar nerd of sorts, it did give me an excuse to link to one of the funniest scenes in that infamous flick.
Kay Engineering's Gundrilling Machine Performs Range of Operations
Kay Engineering’s DeHoff 20144 is used to perform gundrilling, pull boring, roller burnishing and thread tapping.
Emuge-Franken's New Drill Geometry Optimizes Chipbreaking
PunchDrill features patent-pending geometry with a chipbreaker that produces short chips to control machining forces.
