Video: Trial Cuts with Ultrasonic-Assisted Machining
Ultrasonic-assisted machining reduces friction in metal cutting to enable a standard tool to cut faster and more smoothly. Video shows comparison cuts of the same machine and tool with and without this new accessory.
A video created by Acoustech Systems includes footage of holes being drilled with and without ultrasonic-assisted machining. This company’s newly developed system is essentially a toolholder that has ultrasonic actuation built in. Adding this toolholder to the process can actually increase a shop’s machining capacity, because standard machines and tools can cut faster thanks to the friction reduction that the ultrasonic effect achieves. Learn more about ultrasonic-assisted machining in this article.
