A Quick Way to Deburr Holes in Contoured Surfaces
This video shows a device that enables machine tools to quickly deburr both sides of through holes in elliptical and contoured surfaces.
Videos From: 8/5/2011 Modern Machine Shop, Derek Korn,
Loading the player ...
The COFA devices from Heule Tool enables machine tools to quickly and effectively deburr both sides of through holes drilled in elliptical and contoured surfaces. These universal deburring tools use a proprietary TiN-coated carbide blade that is said to achieve fast feeds and speeds and provide long tool life.
As the rotating tool is fed into the hole, the front cutting edge deburrs the top of the hole and the blade rocks upwards. The action of the blade cuts a smooth, tapered edge break from 0.010 to 0.030 inch depending on the tool’s diameter.
While the blade is in the hole, only the ground and polished non-cutting ball touches the wall surface protecting the workpiece from damage while the tool is fed through the part. There is no need to stop or reverse the spindle. When the blade reaches the bottom of the part, its blade springs back into cutting position and the back cutting edge deburrs the bottom of the hole as the tool is withdrawn. Once the blade is back inside the hole, the tool can be rapidly removed and moved to the next hole. The video above shows this process.
COFA tools are available sizes ranging from 0.157 to 1.614 inch (4 to 41 mm). A cassette option is available for larger holes
Heule Tool Corporation
MMS Zones
Zones
Supplier Categories
ERIX tool saves up to 90% of the manufacturing time on back spotfacing and chamfering operations.
Standard grooving tools from .004" in .001" increments with any corner radius. We stock more than 100,000 tools!
Premium tooling and technology for high-quality, precision machining.
