Helical Interpolation Vs. Drilling
A machining center able to maintain precise control at high feed rates makes it practical to machine holes through helical milling as an alternative to drilling. The same speed permits faster drilling, too, so helical milling won’t necessarily be the best approach. Here are applications where helical milling is li
Video from: Modern Machine Shop
Posted on: 8/22/2008
Double Click For Full Screen
The same speed permits faster drilling, too, so helical milling won’t necessarily be the best approach. Here are applications where helical milling is likely to make sense:
  • For chip ejection problems
    Compared to drilling, helical milling makes it easier for chips to clear the hole.
  • Various hole sizes
    Where there are different-sized holes in one part, helical milling can save on tool change time by letting one tool mill multiple diameters.
  • Cored holes
    Holes initially formed through casting can be rounded and straightened through milling more easily than through drilling.
  • Machining threads
    Compared to tapping, helical milling can place threads more accurately, and it can thread a shallow hole more easily. Certain combination tools can also machine threads in the course of machining the hole itself, thereby eliminating a tool change.
