High Speed Air Spindle Example 2: CNC Wood Machining
A Fadal VMC uses an air-driven spindle to create the logo inlay pocket into the headstock of Peavey guitars.
Videos From: 8/1/2011 Modern Machine Shop, Derek Korn,
Loading the player ...
This Fadal VMC uses an air-driven high speed spindle from Air Turbine Tools to create the logo inlay pocket into the headstock of a Peavey guitar. The wood engraving bit is rotated at 25,000 rpm and advanced at 2,000 ipm with a depth of cut of 0.003 inch.
Editor's Picks
High Speed Air Spindle Example 1: CNC Tool Steel Machining
In this video, a hardened tool steel tire mold is milled by an air-driven high speed spindle from Air Turbine Tools.
High Speed Air Spindle Example 3: Robotic Deburring
Using an air spindle, this Fanuc robot is able to deburr castings with irregular flash.
High Speed Air Spindle Example 4: Hand Deburring
Just a light touch is required using this device as its high speed does the cutting. Combined with low vibration and weight, this reduces the risk of ...
Air Turbine Tools
Editor's Picks
Air Turbine Tools
