Micro Laser Welding and Micro TIG Welding
Combining the advanced science of laser technology with the experience in tool and die repair.
Loading the player ...
Micro Tool Welding combines the advanced science of laser technology with the experience in tool and die repair.
Micro TIG welding repair for tool/die mold welding is a good application for non-molding surfaces (for example,  shims, dot proofing, cracked waterlines, major builds, close off runners, etc.). Micro TIG welding is a cost-effective method for mold repair on surfaces that minimum sink is required.  With this process and innovative procedures we’ve become leaders in our field.   Employing the most experienced staff we are able to take on the most challenging job and give you extraordinary results.
High-speed CNC laser welding equipment is the latest technology capable of high quality and close tolerance weld deposits.  This process is used for undetectable or virtually no sink and distortion. Using the newest, most advanced technology on a high speed CNC laser, we can utilize the automated procedures for extreme, precise, high production welding solutions.
These CNC laser welders have a vast traverse range X-axis = 1400mm (55 in.), Y-axis = 2000mm (78.75 in.), Z-axis = 570mm (22.4 in.) and weight capacity of 3000 lbs.  With the combination of micro TIG and laser welding this allows for extremely accurate control and minimum sink and distortion of the entire micro welding process.
