Multi-Axis Spot Drilling
Multi-axis drilling is used in mold base applications.
Videos From: 2/17/2014 MoldMaking Technology
Loading the player ...
Multi-axis drilling, which is common in machining aerospace components, is also used in mold base applications—including the various faces of a simple block.  Multi-axis drilling can save non-cutting cycle time between holes by using smart connections from hole to hole, no matter the orientation.
Learn More
