CAM software with a re-machining feature can create tool paths for removing just what stock remains after high-feed-rate moves have rounded off internal corners. Rest milling (to machine the "rest" of the material) is a term for re-machining. Rest milling generally employs multiple passes. When just one pass is
Double Click For Full Screen
Rest milling (to machine the "rest" of the material) is a term for re-machining. Rest milling generally employs multiple passes. When just one pass is used to let a small tool trace the seam where two surfaces meet, this is called pencil tracing.
Re-machining video courtesy of UGS.
