End Mill Comparisons in CFRP, Part 1 - Carbide Tool
Video shows the performance of coated carbide, diamond-coated, PCD and veined PCD tools in carbon fiber reinforced plastic.
Video from: Modern Machine Shop
Posted on: 8/15/2008
Double Click For Full Screen
Smith MegaDiamond Inc. and Star Cutter Company compared the performance of various end mills in carbon fiber reinforced plastic (CFRP). The tools tested included a coated carbide end mill, a diamond-coated end mill, a conventional PCD end mill with straight flutes, and a “veined” PCD end mll featuring a vein of PCD within a helical slot in a carbide tool body.
The table below summarizes the test parameters. Shown here is the video of a 30-degree helical coated carbide tool. Jeff Michael, engineering manager for Star Cutter, comments, The sound is pretty good for this cutter. It appears to be cutting well until the second pass, where there are visible uncut fibers after just a few feet of cutting.”
To see the next video in this testing, click here.
Tool Type
Ø .500 in.
Solid Carbide
CVD Diamond
PCD
Veined PCD
Flute angle
30° helical
10° helical
7° skew
30° helical
Spindle speed (rpm)
3,000
4,600
12,000
18,000
Chip load (in./tooth)
0.0035
0.0035
0.001
0.0065
Machine advance (in./min.)
42
64
36
470
Radial depth (in.)
.050
.050
.050
.050
Cutting speeds and feed rates were recommended parameters from each tool’s manufacturer.
Learn More
Editor Picks
Zones
Supplier Categories
Forums
