End Mill Comparisons in CFRP, Part 2 - Diamond-Coated Tool
Video shows the performance of coated carbide, diamond-coated, PCD and veined PCD tools in carbon fiber reinforced plastic.
Video from: Modern Machine Shop
Posted on: 8/14/2008
Double Click For Full Screen
Smith MegaDiamond Inc. and Star Cutter Company compared the performance of various end mills in carbon fiber reinforced plastic (CFRP). The tools tested included a coated carbide end mill, a diamond-coated end mill, a conventional PCD end mill with straight flutes, and a “veined” PCD end mll featuring a vein of PCD within a helical slot in a carbide tool body.
The table below summarizes the test parameters. Shown here is the video of a 10-degree helical diamond-coated tool. Jeff Michael, engineering manager for Star Cutter, comments, “Again, the sound is pretty good with this cutter, but uncut fibers appear immediately. This is because a tool’s coating tends to give it a more rounded cutting edge, making it more difficulty to cut the fibers cleanly off.”
To see the next video in this testing, click here.
Tool Type
Ø .500 in.
Solid Carbide
CVD Diamond
PCD
Veined PCD
Flute angle
30° helical
10° helical
7° skew
30° helical
Spindle speed (rpm)
3,000
4,600
12,000
18,000
Chip load (in./tooth)
0.0035
0.0035
0.001
0.0065
Machine advance (in./min.)
42
64
36
470
Radial depth (in.)
.050
.050
.050
.050
Cutting speeds and feed rates were recommended parameters from each tool’s manufacturer.
Learn More
Editor Picks
Zones
Supplier Categories
Forums
