Video: Three-Machine Lean Cell At Richards Industries
VIDEO. For this valve maker, a part that might have been machined in one setup on a multitasking machine tool is instead machined with greater throughput using a series of simpler machines. Company personnel explain.
Videos From: 7/10/2009 Modern Machine Shop
Loading the player ...
Richards Industries applies lean manufacturing techniques to the machining of valve bodies. Modern Machine Shop editor-in-chief Mark Albert speaks with Richards personnel about this application. See two other Richards Industries lean manufacturing videos under “Editor Picks” at right.
Editor's Picks
Video: Increased Productivity With More (Not Fewer) Setups
VIDEO. Valve maker Richards Industries took a part that used to machined at one machine tool and added an additional setup on a vertical machining ...
Video: Grouping HMCs For Greater Efficiency
VIDEO. In a lean machining facility, grouping horizontal machining centers close together allows a small number of operators to use the machines effic...
Mazak Corp.
MMS Zones
Editor's Picks
Mazak Corp.
Zones
Supplier Categories
FUJI machines are built for automation from the ground up.
Power of Evolution.
