11/17/2016 | 6 MINUTE READ
Ceramic End Mills Helps Shop Meet Delivery Date
Stellar delivered the parts on time with zero scrap and is now quoting a second, even larger order.
Connect at
Kennametal will be exhibiting new technology at IMTS 2020 in Chicago this September.
Plan to meet up with their team or get registered here!
Most shops evaluate new cutting tools in an effort to reduce machining time, increase tool life or improve part quality and sometimes all three. Stellar Precision Components Ltd., a Tier II aerospace supplier in Jeanette, Pennsylvania, did it for an entirely different reason. “We’d just taken an order for some Inconel parts,” says production manager, Edward Frieze. “None of us were really worried at that point about tool life or making a profit on the job. Our only concern then was how the heck we could get them shipped in eight weeks.”
Opening Doors
Four decades earlier, Mike Vucish Sr. was working for a manufacturer of naval nuclear components when he saw an opportunity to go into business for himself. He bought some equipment, invited a few students from the technical school where he taught shop class at night, and opened the doors of Stellar Precision in 1978. He continued to work at his day job until his fledgling company was firmly established, but in the meantime brought some family members on board to help out.
“We started out doing a lot of overload work from larger shops in the area, but that evolved into direct support of several nuclear programs because of my father’s experience in this area,” says daughter Lori Albright, now owner and president of Stellar Precision. “We’ve since become a key supplier to a number of prime aerospace and defense contractors, including Boeing, Lockheed, and Raytheon, as well as various nuclear and medical customers, and have more than 70 employees and sales revenues of almost $10 million.”
Stellar prides itself on continual updates to its equipment list and has an eclectic mix of CNC machine tools. Much of its equipment is Haas, which according to Ms. Albright is not only less expensive than its foreign-built competition, but that “Made in America” resonates with many of Stellar’s customers. “This approach also lets us replace our equipment on a more regular basis, which in turn keeps us current on technology.”
Not Too Tough
Stellar is used to meeting demanding requirements. Recent projects include components for Ram Block II anti-ship missiles, the CCtCap crew transport vehicle, 155-mm Long Range Land Attack Projectile (LRLAP) advanced gun system, rocket motor cases for the Atlas Five launch vehicle, and others. Their newest project, however, would be one to test the mettle of machinists and management alike.
Mr. Frieze explains that Stellar had just received a purchase order for a handful of Inconel 625 prototypes. The raw material blanks for the job measured 18-inch square by 3-inch thick (457 by 457 by 76 mm), and weighed almost 300 pounds (134 kg) each. The project team didn’t worry about the tough material’s poor machinability; Stellar routinely cuts Inconel and other nickel-based superalloys, as well as tungsten, maraging steels, 60 Rc 4340 (300M) and tool steel.
Tolerance wasn’t an issue, either. Mr. Frieze points to one recent titanium part that called out a 0.005-inch (0.127-mm) profile tolerance over its 12-inch (304-mm) length, the equivalent of holding “a couple tenths” in parts that cost more than $5,000 a piece before machining. Meeting the relatively wide open tolerances on the Inconel part was not a concern.
The problem was one of raw material removal: when finished, the Inconel plates weighed in at 30 pounds (13.6 kg), 90-percent lighter than their starting weight. Mr. Frieze knew there weren’t enough hours in the day to remove that much material using conventional carbide tooling, not if he were to meet the deadline. He needed a better solution.
Seminar Payoff
Earlier that year, Mr. Frieze and several of his coworkers had attended a learning event sponsored by a local chapter of the National Tooling and Machining Association (NTMA) at the Kennametal technical center in the nearby town of Latrobe, Pennsylvania. There, he met product manager Matthieu Guillon, who introduced him to a cutting tool that Mr. Frieze was initially skeptical of. “It looked and felt like a plastic toy end mill,” he laughs.
That tool was Kennametal’s series of four- and six-flute ceramic end mills. Constructed of SiAlON KYS40 grade ceramic and designed specifically for roughing in nickel-based, high-temperature alloys, these end mills often out-produce carbide by as much as 20 times. Mr. Guillon says, “We recommend a starting speed of 825 sfm up to 3,300 sfm (250 to 1,000 m/min) and feed rates starting at around 0.001 IPT (0.03 mm) depending on the tool diameter and other conditions. Despite the far higher cutting speeds, we have some customers who have reported two to three times more tool life than carbide.”
Stellar didn’t have an immediate use for the ceramic tools, but after making some quick feed and speed calculations, Mr. Frieze knew they would be an effective solution given the right application. Several months later, that application arrived with the Inconel plates. He called Mr. Guillon to say he might have a good use for those ceramic cutters they were talking about and wondered how soon he could get some.
Skeptical to the Last Minute
Mr. Frieze remained skeptical. He’d tried indexable ceramic cutting tools on both milling and turning jobs in the past and had mediocre results. In this case, however, he was willing to try anything if it meant meeting the customer’s deadline. When Mr. Guillon arrived a few days later with the ceramic end mills, Mr. Frieze followed Kennametal’s feed and speed recommendations to the letter, crossed his fingers and pushed cycle start.
“We weren’t certain what would happen, so he started out with a block of test material,” he says. “You don’t use cutting fluid with ceramic—only an air blast—and everyone in the shop was crowded around the machine saying, ‘Wow, look at that!’ There was fire shooting everywhere. It was something we’d never seen before. But within the first hour, we knew it was going to work.”
“The tools aren’t inexpensive,” he says. “At one point, Lori (Ms. Albright) had around $20,000 worth of end mills sitting in her office, and we were starting to question the investment. But once you calculated in the machine costs and reduced cycle time, we figured it was three to four times more cost effective to go this route. Each end mill gave us one half hour of cut time, at which time we replaced it, whether it was worn or not. The process was so predictable that we were able to run lights out. It was a drastic savings.”
Enjoying the Heat
Best of all, Stellar delivered the parts on time with zero scrap and is now quoting a second, even larger order. Ms. Albright was quite pleased with the outcome. “This type of situation is the nature of our business. We have to react to our customers’ needs and employ the best technology available to do so. That’s one of the reasons why Kennametal is so welcome here. We work together as a team to solve challenges.”
Looking forward, Ms. Albright anticipates continued growth. Having expanded Stellar’s existing facility six times, she figures it might be time to put up an entirely new building on nearby property. She also looks forward to bringing additional young people to the machining trade. “We have apprenticeship programs with several of the area schools, one of which was where my father used to teach,” she says.
“I find it’s often our young people that drive our innovation. It’s too easy to keep doing things the old way and not invest in tooling and equipment or pursue new technology. The days of high volume, round-the-clock fender clip manufacturing are gone, and it’s only by continually improving their manufacturing processes that companies can succeed and grow. For us, Kennametal is part of that success.”
For more information from Stellar Precision Components Ltd., call 724-523-5559 or visit stellarprecision.com.
RELATED CONTENT
  • Tips for Tapping Titanium Alloys
    Creating threaded holes in titanium alloys calls for proper techniques based on an understanding of both the properties of these materials and the peculiarities of the tapping process.
  • Taking The Fear Out Of Hard Turning
    To make the transition to hard turning, you'll need to switch from carbide to CBN inserts, but that is easier (and more economical) than you might think. It's making the jump to much higher surface speeds that might scare you off. It needn't. Here's why.
  • 10 Tips for Titanium
Related Topics
Resources
