• MMS Youtube
  • MMS Facebook
  • MMS Linkedin
  • MMS Twitter
1/14/2015 | 8 MINUTE READ
Femtosecond Laser Processing in the Medical Device Industry
Recent advances in the laser technology have brought improved capabilities for precision machining—no thermal effects and minimal post processing.
Microsecond (ms) fiber lasers have been used successfully for medical device applications such as hypo tube and stent cutting for many years. While precise and fast, the down side of this method has been that the parts require a number of post processing operations after they are cut, adding significantly to part cost and increasing the risk of damage to mechanically delicate parts.
In recent years, ultra-short femtosecond (fs) laser technology has been introduced, which produces pulses that leave no thermal fingerprint on the part. These disk-based femtosecond lasers offer sub-400-fs pulses and outstanding beam quality, as well as peak power that enables an extremely high quality cold ablation cutting process rather than a melt ejection process. The resulting cut, therefore, requires minimal post processing, and the smaller beam size allows machining of very fine details.
The process works especially well for production of such medical devices as catheters, heart valves, and stents for medical and glass cutting and marking applications, as well as for 3D structuring of ceramic material for dental implants. But perhaps the most interesting potential use is on a new class of bio-absorbable materials—polymers that safely remain in the body for controlled lengths of time before absorbing—that are being developed as an alternative to traditional polymers or metal components.
In the past, fs lasers have been considered too slow for commercially viable operations. Recent studies evaluated cutting time per part and post processing steps, demonstrating that the return on investment for a disk femtosecond laser can in many cases be less than 12 months, especially for high value components. Because the fs laser’s potential relies heavily on the system platform, Jenoptik and Miyachi America are jointly developing both stage and scan head platforms designed to reach the required level of quality and precision for micro treatment.
Femtosecond Basics
Femtosecond light pulses are ultra-short pulses (USPs). One fs equals 10-15 seconds, and as a calibration point, a 300-fs pulse equates to a physical length of pulse of only 90 micrometers. Because there is no thermal processing as there would be in nanosecond (ns) pulses, USPs have many advantages:
  • No heat impact—no thermal tension in the material and no change of material characteristics
  • No shock waves—no structural changes
  • No micro cracks—smooth processed surfaces
  • No melting effects—no structural changes
  • No surface damages—no rework or after-processing
  • No debris—no cleaning necessary
  • No ejected material—clean surfaces
  • No recast layer—smooth edges
Figure 1 illustrates these effects on an application using a long pulse laser compared with that of an ultra-short pulse laser such as an fs laser.
Femtosecond laser technology is not new; it has been widely used in institutions and research centers for more than 30 years. But commercial-ready fs technology that can last in an industrial environment with a 24/7 qualification has been around for only about 7 years. Originally used for wafer dicing and scribing of P1, P2, P3 solar panels or creating channels in panels for electrodes, fs lasers are now advancing into a new wave of machining capabilities, and many medical devices are excellent candidates, especially given the high cost of the components machined.
In addition to the ROI justification of minimized post processing, the fs disk laser can create unique features that were previously not possible because of quality concerns, particularly with polymer processing. Figure 2 shows the comparison of a nanosecond 355-nm source and a 1030-nm fs disk laser source processing polypropylene. The appearance of the disk fs hole shows little taper and no melting or heat-effect distortion around the hole. This capability enables product design freedom to maximize functionality with little or no compromise to the manufacturing process.
ROI Development Considerations
The edge quality possible with a femtosecond laser for both metals and plastics makes it excellent for machining of heart, brain and eye stents (both nitinol and cobalt-chrome), catheters, heart valves and polymer tubing. The almost cold cutting process means very fine feature sizes can be cut into the thinnest material, while still maintaining mechanical and material integrity. No internal water cooling is needed for even the smallest Nitinol diameter tube.
Quality improvements and the promise of reduced post processing has always made fs laser technology a theoretical possibility, but until about 6 years ago there was little commercial interest in its use for medical devices because of concerns about the expense and slow speed compared with other technologies.
Companies including Jenoptik have since developed an ROI tool to illustrate the true cost of post-processing. The tool can be used to factor in overall costs, including laser equipment purchase, post-processing capabilities, machine time and handling time. The calculations demonstrate that femtosecond lasers are actually faster, because they alleviate several extremely time consuming post-processing steps.
Take the example of the universal coronary stent—one of the first devices to be manufactured with a fiber laser. First, the part must be machined, then honed, or cleaned out inside with a mechanical tool, and finally deburred. Then a chemical etch process must be performed to clean up around the edges, followed by an electropolishing step. Not only are these steps time consuming, but they can also cause the part to become brittle and deformed and can produce micro cracks. Yields tend to be in the 70 percent range, meaning a significant amount of end product is lost. By contrast, the fs laser is a dry format—no water or heat is introduced in the part. The number of steps is drastically reduced; the part is machined and then undergoes an electrochemical process to round the edges. The integrity of the part is improved, several time consuming steps are eliminated and yields can be closer to 95 percent.
Figure 3 shows the high cutting quality of the fs laser for cutting of nitinol stent material. The use of the fs laser prevents burr, and the slight roughness of the cutting edge gives a good precondition for the electropolishing process. Removal rate in this example was 0.25-5 mm/sec and material thickness of up to 400 micrometers is possible.
The fs laser is also capable of machining medical products out of new bio-absorbable polymers, which can be safely implanted in the body for controlled lengths of time before absorbing, without causing harm or adverse interactions. Advanced bioabsorbables (also called aspirants) provide an alternative to traditional polymers or metal components and are being designed to meet precise degradation rates and other specifications.
The bio-absorbable material can be machined into any profile that can be used for stents. However, it must be machined correctly and without inducing heat. Failure to do so might lead to crystallization in the material, which would degrade its structure and affect its lifespan and ability to dispense medicine at the correct rate. Also, because bioabsorbables dissolve, they cannot be cleaned like most plastics, nor can they be touched with any liquid solutions—another reason the fs laser is a better choice for the material.
Bioabsorbables are already being used for coronary stents in the European Union, although they have not yet received FDA approval for use in the U.S. Mostly composed of polyesters, primarily homopolymers and copolymers of poly(lactic acid) and poly(glycolic acid), bioabsorbables are showing promise for a variety of uses, including cardio stents for patients who may have been stented numerous times and can no longer tolerate a traditional fixed stent. The material is also being used to deliver medicines into organs of the body by being inserted into the organ, dispensing the medicine at a consistent rate, and eventually dissolving in a predetermined amount of time. Figure 4 shows an example of an fs laser cut of a bio-absorbable stent.
After years of clinical trials, several firms are awaiting approval and already planning for the new innovation to hit the U.S. market, and several have been qualifying use of fs laser equipment to gear up for the precision micro-machining required.
Femtosecond Laser and Micromachining
The industrial robustness of the disk fs laser needs to be matched to an equivalent system to deliver the day-in/day-out reliability that the medical device industry demands. The fs laser cannot currently be fiber-delivered and, therefore, is directed and delivered to the focusing optics by fixed mirrors. Thus, designing a beam delivery system for a four-axis tube cutter that can make off-axis cuts while maintaining alignment can be a challenge. The optical path design has to ensure that such key optical tools as the beam expander and fine tuning attenuator are easily accessible as needed for process development. The system design requires full mechanical isolation, and in some cases, ambient temperature stability, to provide a system foundation for process repeatability.
Jenoptik teamed with Miyachi America to develop the system integration capabilities necessary to move the femtosecond laser into the marketplace. The first developed platform was based around Miyachi’s Sigma Tube cutter.
Designing precision micromachining systems may appear to be dependent only on how much granite is used. While there is no doubt that mechanical stiffness and isolation are required, these factors are simply the starting point. Determining how delicate parts and materials will be repeatedly positioned or clamped, implementing in-system part inspection, and incorporating real-time optical beam diagnostics are several other key pieces of the puzzle.
The beam is directed through the system by mirrors, so maintaining optical alignment is important. But this is only the first step. Ensuring that the beam profile and power levels are maintained requires the use of optical diagnostic tools, and these tools must be in line and non-intrusive, providing real-time information. The tool is usually mounted directly after the laser and the last turning mirror in the beam path to enable deviations to be isolated to the laser or the optical beam path. Being in line and non-intrusive enables data collection during processing that can be time- and date-stamped as part of the manufacturing data.
Bright Future
The femtosecond disk offers unique, in-class process capability with excellent beam quality and high peak powers. To maximize the process capability for production, the laser must be integrated into a system that enables high quality and repeatable processing. The combination of a robust femtosecond product that has been on the market for more than 8 years with an experienced micro systems provider with in-house parts processing capabilities results in a partnership geared toward developing ideal production system solutions for high value medical products.
RELATED CONTENT
  • CAM System Simplifies Swiss-Type Lathe Programming
    To reduce setup times, this medical device manufacturer replaced its conventional CNC turning and milling machines with Swiss-type lathes. However, taking full advantage of these complex machines’ capabilities required another investment—Esprit CAM software from DP technology.
  • Machining For Air
    This shop makes the oral devices that helped the shop owner and members of his family. Unattended machining is the key to making this therapy more accessible.
  • A Big-Picture View of Micromachining
     Matrix Tooling makes injection molds for components that have features you cannot see.
Related Topics
Resources
