| 1 MINUTE READ
November 2018 Product Spotlight: Cleaning and Deburring
This month’s Modern Equipment Review Spotlight focuses on equipment used to finish parts by removing burrs, oils and other contaminants.
#partscleaning
The image gallery above, based on Modern Machine Shop magazine’s Modern Equipment Review Spotlight, features a variety of finishing equipment for deburring and cleaning finished parts. Several of these technologies were displayed at IMTS 2018 in September. Swipe through the gallery for details, and follow the caption links for more information about each item.
RELATED CONTENT
  • Drill And Bore With A Face Mill
    Cutting holes by interpolating a face milling cutter may be a better process choice for many rough and even finish boring operations. Software improvements and better cutter designs allow expanding use of the versatile face mill for hole making.
  • Non-Traditional Methods For Making Small Holes
    Consider these alternatives when conventional drilling can't do the job.
  • Rigid Tapping--Sometimes You Need A Little Float
    One of the most common methods of tapping in use today on CNC machines is 'rigid tapping' or 'synchronous feed tapping.' A rigid tapping cycle synchronizes the machine spindle rotation and feed to match a specific thread pitch. Since the feed into the hole is synchronized, in theory a solid holder without any tension-compression can be used.
