1/26/2015
Tooling App Updated
OSG Tap & Die has upgraded its Tool Selector app which provides tool recommendations based on users’ applications.
OSG Tap & Die has upgraded its Tool Selector app which provides tool recommendations based on users’ applications. The update enables users to add the app to the home screen of mobile devices including iPhones, iPads, iPods and Android smartphones.
RELATED CONTENT
  • Taking The Fear Out Of Hard Turning
    To make the transition to hard turning, you'll need to switch from carbide to CBN inserts, but that is easier (and more economical) than you might think. It's making the jump to much higher surface speeds that might scare you off. It needn't. Here's why.
  • Tool Considerations for High Speed Cutting
    Fast CNC processing and high-pressure coolant contribute to removing metal at dramatic rates. But what should a shop know about cutting tools in high speed machining?
  • Successful Application Of Ceramic Inserts
    Applying ceramic inserts is not a simple substitution of one cutting tool material for another. There are significant process considerations that shops should examine carefully in order to realize performance and tool life expectations from ceramic inserts. Here's a look at some of the ways they are used.
Resources
