9/18/2015 | 10 MINUTE READ
Bar Feeder Basics
Last updated on 7/15/2019
Some primary factors are often overlooked when considering how to justify the implementation of a bar feeder for turning operations.
Connect at
CNC Indexing & Feeding Technologies will be exhibiting new technology at IMTS 2020 in Chicago this September.
Plan to meet up with their team or get registered here!
A bar feeder seems like a relatively simple device. The most common automation accessory in our world of high volume turning, it provides a reliable way of delivering material to the machine tool for extended periods of time, saving an operator from continually loading blanks into a chuck.
In reality, bar feeders have many nuances from one to another to make them more suitable to certain shop environments. Length and capacity are only the beginning. Other factors should be considered during the purchasing process as well.
CAD/CAM Software Helps Shops Shift to Coronavirus Work
CNC Machine Shop Reaps Benefits of Hiring an IT Person
Length and Capacity
Visually, the most obvious difference in bar feeders is the length. Generally, full-size bar feeders are capable of feeding 12-foot-long bars (some are even longer). Short loaders can handle up to 6 feet, while spindle-length bar feeders are designed for 3- and 4-foot lengths. One consideration in determining which kind to purchase may be floor space limitations, but other factors may be significant enough to sway a shop to find the necessary square footage.
Magazine Bar Feeder
Magazine bar feeders hold multiple bars in reserve to extend the time a machine can run unattended.
Twelve-foot bar feeders are often considered a requirement for sliding headstock Swiss lathes. Spindle-length loaders only load bars as long as the lathe spindle. Clearly, the floor space they take up is a lot less, but the customer must cut the bars into 2-, 3- or 4-foot sections to the length of the lathe spindle.
Another advantage of the 12-foot bar feeder is that it produces fewer (and typically shorter) remnants. With each section of bar loaded, a shop should expect a single remnant, so cutting the 12-foot bar into three or four pieces will result in three or four remnants. Because Swiss machines typically are running short cycle times, the 12-footer makes more sense to extend the production run.
To take full advantage of the 12-foot bar feeder’s capacity to allow long runs (often 8 hours or more), the magazine style, which holds multiple bars in reserve, should be used. Conversely, single-tube bar feeders, which handle 12-foot bars exclusively, take up even more floor space. They are about 20 feet long because they don’t have the dual feeder for the short pusher versus the long pusher.
12-Foot Bar Feeder
But when bar diameters get up to about 2 inches, 12-foot magazine bar feeders begin to get far more expensive, according to Joel Jones, service technician for CNC Indexing & Feeding Technologies. His company offers 12-footers up to 2-inch diameter and short loaders with maximum diameters ranging from 2.5 inches to 4 inches. “There’s a huge cost difference if you want to feed a 3-inch bar on a short loader versus a 12-foot bar feeder. The cost escalates enormously, but sometimes that cost can be justified,” he says.
Straightness is often dependent on the material supplier, but a bar can also be ground for straightness.
While bar straightness is not as critical on short loaders, it’s quite important on the 12 footers. If the bar is not straight, then it will vibrate in the bar feeder, be noisy and will affect the finish on the part. The bars can run with a little bit of bend or runout, but too much will cause severe vibration and will negatively affect the finish of the part. Straightness is often dependent on the material supplier, but a bar can also be ground for straightness. If it is to be run on a Swiss machine, it’s almost always ground for size and straightness to accommodate the guide bushing.
Magazine bar feeders play a significant role in lights-out turning operations. Mr. Jones explains one customer who is producing complex washers, targeting 10-second cycle times. “If they were using a single, 12-foot bar, they’d only be able to run it for an hour and a half,” he says. By being able to put 10 bars in the magazine bar feeder, they can easily run through the night. The aluminum part is forgiving, and diamond or PCB tools provide reliable tool life. “Besides having enough material, important factors for lights-out include size and complexity of the part as well as tool life,” he says. “The magazine bar feeder will allow the machine to run unattended as long as the process allows it.”
Bar diameter directly affects the capacity of the bar feeder. Typical of most bar feed manufacturers, the majority of the 12-foot magazine bar feeders offered by CNC Indexing will hold about 23 bars at 3/8-inch diameter. In Swiss sliding headstock operations, 38 mm is commonly the largest diameter size. In that case, these bar feeders would hold about seven bars.
Another possible consideration for the capacity of a bar feeder is the total weight of the material that is being loaded. The total weight of seven 1.5-inch 4140 stainless bars is considerable. While bar feeders from CNC Indexing do not have weight restrictions, others may. If weight is limited, the number of bars that can be loaded may be limited, which would also affect the length of time the machine can run unattended.
Feeding the Bar
Other available features on bar feeders can affect how accurately the bar is fed through the machine. With a servo-driven bar feeder, the control allows the operator to specify how far the bar should be fed through the spindle, based on what is needed for the next part. A pneumatic system, on the other hand, uses air to drive the pusher and push the bar until it hits a turret stop. Both styles have their advantages, whether cost, accuracy or speed.
Bar Pusher
During operation, a pusher retracts all the way to the end of the feeder, a new bar drops in to the channel, and the pusher feeds the bar in as it is needed. The channel keeps the bar from vibrating or moving up and down.
Pneumatic bar feeders are generally less expensive, but could result in more remnant or waste. When the bar is fed, the stop may not be positioned precisely, sometimes allowing the bar to be fed as much as a quarter inch further than necessary. This material will be faced off, so that much material will be lost for each time the bar is incremented, in addition to the remnant at the end of the bar. While bars that are fed with a servo-driven feeder, which is more precise, are often faced as well, it’s only a minimal amount. (Servo-driven feeders are more precise and usually don’t need a stop, saving a tool position.) Of course, the type of material being used is significant in determining the cost advantages either way, as any losses in exotic materials such as titanium or Inconel can add up quickly.
Instead, people will buy 12-foot bars and then, based on the length of their headstock, rather than cutting a 12-foot bar in half and having two 6-footers, they might cut it into four 3-foot bars or three 4-foot bars
When people are shopping for a short bar feeder, they sometimes assume they can cut their 12-foot bars in half and run 6-foot bars. But with these short bar feeders, they are limited by the length of the headstock. Whatever the difference is between the length of the headstock and the length of the bar will be the length of the remnant because the bar feeder can’t push past the start of the headstock and does not handle the bar while it is turning in the machine.
6-Foot Bar Feeder
Short bar loaders are capable of loading spindle-length barstock into the lathe spindle Their smaller size is often better for shops with limited floor space.
Instead, people will buy 12-foot bars and then, based on the length of their headstock, rather than cutting a 12-foot bar in half and having two 6-footers, they might cut it into four 3-foot bars or three 4-foot bars, which gives them more remnant pieces, but allows them to use the majority of the 12-foot bar rather than taking it and having one long remnant.
Bar Feeder Comparison
With a servo-driven bar feeder, the control allows the operator to specify how far the bar should be fed through the spindle, based on what is needed for the next part. A pneumatic system, on the other hand, uses air to drive the pusher and push the bar until it hits the turret stop.
In many cases, the remnant isn’t necessarily waste, as it can be used on another machine by putting it into a chuck as a blank to make a part. But in production shops that are running large runs, putting all of those remnant pieces into a chucker is not practical, so they become waste. This situation is typical in the Swiss market, where common remnant lengths are between 2 to 6 inches. These are almost always waste because of the short cycle times.
A Good Fit
Depending on the diameter of the barstock and spindle, spindle liners can be used to compensate for considerable differences. The liners are available in different diameters to fit the different bar sizes. For a long time, spindle liners were made from steel, which would be noisy with out-of-round stock. The vibration would also cause the liners to wear out. In the last 10 years or more, polyurethane liners have become popular, allowing for quieter operation and easier modifications of the liners if needed for other machines.
The liner is installed into the spindle, holding a good fit for the bar to help keep it straight and keeping the centerline of the material fed in on the chuck’s centerline. Steve Smith, president at CNC Indexing, says, “If inch and a half bar is being fed through a 3-inch spindle with no liner, gravity would cause the material to drop down to the bottom of the spindle. As it comes through the chuck, the centerline would be off.”
According to Mr. Smith, a rule of thumb for spindle liner diameter is that it should be no more than 100 thousandths larger than the material size. With plus/minus specifications for material, bars can come in larger than the quoted size, so the liner needs to be able to accommodate that difference. While some range is necessary inside the spindle liner, it should fit the material as closely as possible to avoid whip in the material as it is rotating.
Smaller diameters and the lack of bar straightness will cause more tendency for whip and, therefore, increase the importance of a good fit in the spindle liner. “If you have a 3-inch spindle liner installed and you switch to a 2-inch bar, you don’t necessarily have to change to a smaller liner, as long as the bar is pretty straight,” Mr. Smith says. “But you need to match spindle liners more to the size of the material as it gets smaller.”
Improving Efficiency
Minimizing operator intervention, even to the point of lights-out operations, is the main reason for using bar feeders. But shops should also consider the cost of employment, as personnel and floor space are the largest expenses a shop usually faces. So when considering how much space a bar feeder may occupy, a shop owner should also think about how it may make the production process more efficient.
People often think that to maximize the use of a bar feeder, they need to be running the same part over and over in a production run. Mr. Smith says that’s simply not true. “Most shops are running mostly the same types of material and similar part sizes,” he says. “A shop can run 500 pieces with a bar loader, and while that job is running, the operator can be overseeing two other machines. When the first job is complete, the operator can quickly load the program for another part of similar size and have the machine up and running again. Even if the cycle time is 3 minutes on a conventional lathe, do you really want to pay an operator to stand there and wait, then open the door, pull out the part and put the next blank in for each piece when a bar loader can free him up to be more productive by running other machines at the same time?” Even in small lots, shops are always looking to be more efficient, trying to increase throughput with shorter lead times.
Like other forms of automation, bar feeders can make a big difference in a shop’s efficiency and higher production rates. It’s important to weigh the advantages of different models to determine what is the best fit for each situation, but as long as space and cost allow, the bar feeder may provide the right boost to turning operations.
Also read, “Choosing an Automatic Bar Feeder.”
Learn more about bar feeders by visiting the Bar Feeders and Material Handling Zone.
RELATED CONTENT
  • Making The Most of Modular Fixturing
    Modular fixturing makes sense for this manufacturer, whether it's machining one- or two-of-a-kind parts for its custom machine tools or larger quantities for its contract machining business.
  • Multitasking's "Big" Advantage
    As demonstrated at this Cincinnati-area shop, machines that both mill and turn shine brightest when workpieces are massive.
  • A Study Of The Steady Rest
    When the length and stiffness of a workpiece make it difficult to machine without distorting or deflecting the part, many manufacturers turn to the steady rest as a workpiece support device. This is especially true for long axles, shafts and similar parts used in automotive or heavy equipment applications, and in oil drilling components. The most common application is to support a workpiece during turning or milling and, increasingly, during secondary operations such as ID drilling, boring and producing end face bolthole patterns.
Related Topics
Resources
