NTMA
ERP Leads CNC Machine Shop to Adopt a Paperless Initiative
Enterprise resource planning software is not only enabling Chapter 2 to better manage its range of capabilities, but also to help it go paperless.
Chapter 2 CNC machine shop
Chapter 2 has added two robotic machining cells like this one to machine flywheels for small engines.
Amanda Johnston, marketing specialist for Chapter 2 Inc., says the contract manufacturer has expanded and implemented a number of changes to become more efficient since it was named a Top Shops winner in 2015.
The Lake Mills, Wisconsin, company has a range of in-house manufacturing capabilities including CNC machining, welding, assembly and painting, as well as workholding-device and tool-and-die manufacturing. In the last five years, it has added a wealth of new capital equipment. This includes turning centers, horizontal machining centers, a new side-down-draft paint booth, urethane molding process and coordinate measuring machine (CMM). It has also expanded its facility by 20,000 square feet, bringing total floor space to 100,000 square feet.
The shop also has added two robots to create two cells producing flywheels for small engines. Each cell features two CNC lathes. This enables one person to tend two machines, whereas before adding the robots, one person for each of the four machines was required. The cells increase throughput and also eliminate the repetitive motions formerly required of these employees to maneuver 20-pound workpieces by hand.
Chapter 2 has also made significant changes on the software side of things. It moved away from basic accounting software to an enterprise resource planning (ERP) system in 2016. The issue with the accounting software is that it lacked work order and shopfloor control capabilities that the company felt it needed. That software worked fine for inventory management, but had no job tracking capabilities. Plus, one part number could have a variety of spreadsheets tied to it. All this was exacerbated given that the shop had so many different manufacturing departments through which a job might run.
With ERP, all job information is tracked in one place, and the shop can easily see the status of every job on the shop floor.
Since adding the ERP system, all job information is tracked in one place, and the shop can easily see the status of every job on the shop floor. “It also has eliminated a lot of paper use, as employees used to hand in a printed timecard at the end of the day where they listed what jobs they ran, how many parts were produced, run time and so on,” Ms. Johnston says. “Now, the ERP system captures all the information for us when employees log in to a job within the system.”
ERP is especially helpful for tracking jobs at Chapter 2, given that the shop has so many different manufacturing departments jobs might run through. Here is the shop’s paint department.
Chapter 2 has also developed its own computer application, which has further reduced its reliance on paper documentation. “Previously, we printed hard copies of all work instructions and inspection logs that employees then filled out by hand at the end of their shift,” she explains. “Those logs were then filed in cabinets and stored. Today, employees use our app, and all that information is stored in a database.”
Chapter 2’s recent facility addition brought total floor space to 100,000 square feet.
The first job for which Chapter 2 chose to implement this paperless process was the flywheel part mentioned above, a job that required a number of inspection logs. The process is also helpful when employees’ time is split between multiple jobs by allowing for a more effective means of tracking true labor cost for each job. In addition, the process acts as a customer service tool. For example, if a customer were to call asking for immediate delivery of parts for a given job, a manager could see how many parts for that job have been completed and could be delivered. It would also be easy to provide a good estimation of delivery time for the remaining parts.
This aligns with Top Shops benchmarking results over the course of the survey’s 10 editions. Successful shops are more likely to have an ERP system than lower-performing shops. And those that participated in this year’s survey, our tenth edition, should be getting their custom reports soon. If you didn’t participate this year but are interested in survey results, visit gardnerintelligence.com.
MMS Top Shops
NTMA
Become a NTMA member today!
MMS Online Apr-2021
topshops
Top Shop Builds Upon Employee Ownership for Future Success
In its quest to become the Fox Valley’s best-in-class employer, A to Z Machine has adopted an ESOP, expanded benefits and invested in apprenticeships.
topshops
Business Award Winner Gains Traction on Strategic Vision
KLH Industries joins the 2022 Top Shops Honors Program with a renewed sense of identity, a new leadership team and new tools for driving growth.
topshops
Building a Better Business: Lessons for Machine Shops From an Unexpected Source
Learning how to be a great manufacturer by listening to the insights of a different industry, homebuilding (which perhaps is not so different after all).
Shop Management Software
ERP Software Enables Paperless Manufacturing
Smart Manufacturing Experience 2018: Kairos Manufacturing Solutions, reseller of ProShop software from Adion Systems, will be sharing insights into the benefits and value of ERP for manufacturing management.
ERP Software Improves Aerospace Shop’s Operational Efficiency
Talsco Manufacturing Inc. improved its operational efficiency by implementing new ERP modules from Realtrac.
Find out more about NTMA Events
