3/4/2020 | 2 MINUTE READ
How to Improve 3D-Printed Conformal-Cooled Mold Insert Performance
Originally titled 'How to Improve 3D-Printed Conformal-Cooled Mold Insert Performance '
Coated conformal cooling channels can prevent scaling and corrosion in injection molds, increasing heat transfer, improving performance, and reducing outages.
mold
Cleaning 3D-printed conformal cooling channels in tooling like this is a challenge, but the right surface treatment can help. Image courtesy of Alcadyne.
Production Additive Manufacturing Is Already Happening
3D-printed molds with conformal cooling channels yield more efficient heat transfer, but the geometrically intricate channels may increase the likelihood of scaling. Scaling decreases flow and worsens the integrity of the cooling channel walls, which leads to leaking.
Maintenance solutions for eliminating scaling and corrosion range from cooling channels flushing with aggressive cleaning media that can damage the mold, to gentler ultrasonic cleaning that may be ineffective. Shops also opt to fix leaking cooling channels, which has high costs and downtime, and, in many cases, is not possible.
Another option for combating scaling and corrosion is to coat the inner diameter of the cooling channels.  Most mold builders and parts manufacturers are familiar with electroplating or PVD coating mold surfaces to increase hardness and to extend mold life, but many do not realize that a surface treatment to the inner cooling channels will improve the lifespan of a mold’s interior as well.
Applying a thin layer of internal, ultra-thin, thermally conductive ceramic coating can provide several benefits that ultimately prolong the lifespan of the cooling channels, provide better uptime and save an injection molder money. The coating is thin enough (50-100 microns) that it has no measurable effect on heat transfer.
This coating in the cooling channels has the following characteristics and benefits:
  1. The coating creates smooth walls that decrease scaling, as dissolved minerals and impurities have difficulty gaining a foothold in the channels.
  2. The coating provides a layer between the cooling water and the metal wall, preventing dissolved metals from occurring.
  3. A uniform coating throughout the inner diameter of the cooling channels promotes a uniform thermal gradient.
  4. The very hard coating (9.0 on Mohs Hardness Scale) limits pitting corrosion.
  5. The coating seals any micro cracks or voids that may have formed during fabrication or heat treating.
  6. The coating formulation is chemical-and solvent-resistant, allowing it to be used in conjunction with an aggressive chemical clean of the cooling channels during maintenance.
  7. After over 1,000 hours (ASTM B117) in a salt fog test the coating formulation exhibited no blistering, cracking, softening or delaminating, demonstrating robust resistance to water and mineral content.
The coating is also effective in fixing molds that leak as a result of inferior 3D prints with voids in the cooling channel walls or inadequate traditional mold fabrication. This coating application can serve as an inexpensive alternative to welding repair or mold replacement.
Before you start a production run with a new mold or retire a leaking mold, consider having the inner diameter of the cooling channels surface treated. This step will reduce maintenance stoppages, improve cycle times and reduce mold replacements.
Alcadyne LLC
RELATED CONTENT
  • What Is Directed Energy Deposition?
    Analyzing directed energy deposition and powder-bed fusion provides a thorough understanding of the extra machining necessary for a “near net shape” versus a “net shape” manufacturing process.
  • Redefining Plastics Manufacturing
    When this company was solely an injection molder, job quantities had to be large. Now, with additive manufacturing, any quantity is right. The company's role and its range of customers have both expanded.
  • The New Pattern for Prototyping
    Ford is building engineering confidence through nearly production-ready prototype parts, which provide reliable test data—all thanks to additive manufacturing.
Related Topics
Resources
