12/18/2018 | 1 MINUTE READ
Integration Leads to Automation Success
Choosing the right components is only the first step in setting up an automated cell—they must also be integrated properly.
When Standby Screw Machine Products was facing quality issues related to inconsistency when hand-loading machining centers, it knew that automation was the answer. But it needed to find the right solution—one that could run a variety of parts. The company purchased a Tongtai TMV-510T machining center with a rotary pallet changer, a FANUC 200iD 7L robot and a conveyer system to build an automation cell. The next step to getting it up and running was having an integrator link the three components. The article “Moving Automation In” gives a look at this process.
Standby worked with the distributor, Absolute Machine Tools, which is also a certified FANUC integrator, to connect the system. This involved connecting the machine’s control to the conveyor and robot via Ethernet cables. Because the system uses only the machine’s control instead of computers on every component, it only requires one start button and one stop button. The system also required a specialized workholding system and grippers to accommodate the different parts the machine makes. Co-Op Tool created a custom, automated, quick-change system that could handle all the parts needed.
With the cell up and running, Standby was able to increase production and reduce loading errors, all while reducing the number of machines and employees needed. These employees are now freed up to do higher-value work, like programming. Read “Moving Automation In” to learn more.
RELATED CONTENT
  • Bar Puller Basics
    Bar pullers are cost-effective alternatives to enable automated turning on CNC lathes. This article explains how they work and how shops can benefit from using them.
  • Flexible Robot Arm Boosts Production
    By incorporating Universal Robot’s UR5 robot arm into its production process, RSS Manufacturing & Phylrich was able to take on a new job and free 30 percent more capacity from existing machines.
  • Machining with Robots
    Several exhibitors at the recent EMO show in Hannover, Germany, featured demonstrations of robotic arms wielding live cutting tools such as end mills or face mills. Perhaps the most dramatic demo was presented by Delcam to showcase this CAM developer’s PowerMill Robot Interface.
Related Topics
Resources
