Kennametal's KOR 5 End Mill Enables Higher Feed Rates Roughing Aluminum
Kennametal’s KOR 5 solid carbide end mill is designed for high-speed aluminum roughing in aerospace applications.
Kennametal’s KOR 5 solid carbide end mill is designed for high-speed aluminum roughing in aerospace applications. The five-flute tool is said to allow for increased feed rates of 66% compared to three-flute tools.
A tapered core, variable-pitch design and 35-degree helix reduce chatter and tool deflection, the company says. Through-tool coolant flushes chips away while reducing heat. The tool’s chip splitter pattern is designed to break up long chips to avoid recutting while also contributing to surface quality.
The KOR 5 enables machining with low radial engagement but high depth of cut, resulting in higher metal removal rates than traditional methods, according to Kennametal. Use with the company’s Safe-Lock shanks increases the tool’s predictability and prevents pull-out at higher feed rates.
Five-Axis Changes Weldments Into Monolithic One-Piece Parts
Moving from welding to five-axis machining enabled Barbco to redesign its weldments as monolithic one-piece parts with improved strength and repeatability.
