Milltronics Introduces Largest XP-Series VMC
Milltronics USA’s VM8434XP vertical machining center is built with linear cross roller guides for rigidity, direct-coupled ballscrews for faster response, and a dual-wound spindle motor for faster acceleration/deceleration as well as added torque.
Milltronics USA’s VM8434XP vertical machining center is built with linear cross roller guides for rigidity, direct-coupled ballscrews for faster response, and a dual-wound spindle motor for faster acceleration/deceleration as well as added torque. The 35-hp machine also includes a heavy-duty belt-driven, 8,000-rpm spindle that generates 365 foot-pounds of torque with a maximum cutting feed rate of 500 ipm.
The 50-taper machining centers in the company’s XP series are designed for applications that need extra cutting power. Features such as coolant rings and washdown systems, lift-up chip conveyors and CNC height adjustment are standard on XP-series machines. The VM8434XP is the largest Milltronics XP machine with X-, Y- and Z-axis travels measuring 84" × 34" × 30", respectively, and a 86" × 34" table.
XP machines are equipped with the 9000-series control that includes 120 GB disk storage, 4 GB memory, improved graphic performance, mid-travel tactile keys and a 15" LCD touch screen. The 9000 control allows operators to run parts programmed either conversationally or by tool paths generated by a CAM system. The control also supports the optional ChipBoss feature that algorithmically calculates tool paths and manages maximum allowable cutter engagement.
Vertical Lathe Executes Heavy-Duty, Long and Continuous Cutting
New VT1000EX Vertical Lathe from Okuma America Corp. possesses the capability to cut and machine difficult materials through, according to Okuma, its highly rigid, mechanical configuration, extreme thrust and torque.
What to Do When Five-Axis Machining Is Off the Table
For Fischer USA, 3+2 machining with a high-precision rotary table adds flexibility without the cost of a full five-axis machine.
