| 1 MINUTE READ
“Pay as You Go” Probing?
With this atypical concept, users purchase a six-month credit token that enables unlimited use of an on-machine probing system during that period.
The tool-setting probe automatically measures a tool’s length when the tooltip contacts the probe axially.
Shops can benefit from on-machine probes in multiple ways. Setups can be faster by probing to establish the location of a workpiece fixtured on a machine so the part program can be aligned to it. Probing can also be used for process control, whereby cutter compensations can be applied based on part measurement data. Plus, a tool-setting probe can automatically measure tool length and tool diameter to further speed setup time for a new job.
Renishaw offers a new twist on the on-machine probing concept: minimizing upfront costs by using a “pay as you go” model, whereby users purchase a six-month credit token that enables unlimited use of a probing system during that period.
Related Topics
RELATED CONTENT
  • Composites Machining for the F-35
    Lockheed Martin’s precision machining of composite skin sections for the F-35 provides part of the reason why this plane saves money for U.S. taxpayers. That machining makes the plane compelling in ways that have led other countries to take up some of the cost. Here is a look at a high-value, highly engineered machining process for the Joint Strike Fighter aircraft.
  • Gaging Countersunk And Chamfered Holes
    While countersunk and chamfered holes are similar in appearance, functionally they are quite different. Consequently, different gages exist to serve these different functional requirements.
  • Surface Texture From Ra to Rz
    The irregularity of a machined surface is the result of the machining process, including the choice of tool; feed and speed of the tool; machine geometry; and environmental conditions. This irregularity consists of high and low spots machined into a surface by the tool bit or a grinding wheel.
