Removing Burrs Can Be a Blast
Having trouble deburring the inner passages of a solid metal part? Read about how one company found the solution in Thermal Energy Machining (TEM), and is having a blast in the process.
An oxidized part immediately after undergoing TEM deburring. The residue will be removed during post-washing in a neutral solution.
Lubos Hanulik, product line manager at Danfoss Power Solutions in Ames, Iowa, is an experienced engineer. But he’s also a pretty good teacher. I discovered this while visiting with him to learn—and write an article—about a highly automated cell he helped develop using the Thermal Energy Method (TEM) to burn away burrs in the internal chambers of two components of a hydrostatic transmission. I found this to be a fascinating experience because, not only did I get to learn about TEM deburring, which ignites an oxygen/methane mix that removes burrs via oxidation, but also about the thought process behind creating a machining cell from scratch.
In short, the cell incorporates Mazak HCN 6000 horizontal milling machines, FANUC robots and a custom-designed washer and a P400 five-station TEM machine from Kennametal Extrude Hone to carry castings all the way from initial machining to the finished product. The parts—an end cap and a connector—are then ready for final assembly about 50 yards away. The entire operation is overseen by a single operator.
Although you may have a completely different application, much can be learned from Mr. Hanulik’s approach to developing this cell.
Ingersoll Rand Offers Two New Belt Sanders for Smooth Finishes
Ingersoll Rand’s 360-313 and 360-418 Pneumatic Belt Sanders work effectively on metal, plastic, fiberglass, wood and other materials.
Trumpf Deburring Tool Provides Repeatable Accuracy
The TruTool TKA 1500 edge milling tool is now available with a new cutting mount and guide fence for increased applications and safety.
