10/3/2016 | 1 MINUTE READ
Take This Tool for a Spin
Turbo whirling is a newly developed process from Horn USA that optimizes machining during thread whirling, boosting both productivity and cost-effectiveness.
You can see how the cutting division concept of the nine-insert tool allows machining to be divided up so that each cutting edge is subject to equal load, leading to significantly longer service lives.
While visiting the Horn USA booth at IMTS 2016, the subject arose about which new machining process was being placed front and center for visitors to see. The answer? Turbo whirling. In a nutshell, turbo whirling is a newly developed process that optimizes machining during thread whirling, thus increasing cost effectiveness. According to Horn, it has developed a set of cutting tools for whirling that feature a new cutting division concept specifically designed for machining threads with a large allowance.
It seems that individual cutting edges work as pre-cutters and machine the workpiece to the defined external diameter. In the case of a nine-insert tool, the company says, the cutting division concept allows the machining work to be divided up so that each cutting edge is subject to equal load. This means that individual cutting edges can achieve significantly longer service lives. The finishing cutting edges produce the finished thread flanks within the optimized working range. In addition, regardless of the external workpiece diameter, combining a range of cutting edge profiles creates an optimum thread with reproducible tool lives.
Horn says turbo whirling can be used to produce single-start and multi-start threads and profiles. What’s more, the S271 precision-ground double-edged indexable inserts are tailored to the respective thread profile and the material to be machined. The indexable inserts are clamped in positive-fit, highly stable insert seats, either in the new modular whirling heads with optimized handling during insert replacement or conventionally in the Mono block tools. Read about Thread Whirling Basics in this article from a past issue of Production Machining
RELATED CONTENT
  • Drill And Bore With A Face Mill
    Cutting holes by interpolating a face milling cutter may be a better process choice for many rough and even finish boring operations. Software improvements and better cutter designs allow expanding use of the versatile face mill for hole making.
  • Start With The Right Speeds And Feeds
    Running rotary milling cutters at the proper speeds and feeds is critical to obtaining long tool life and superior results, and a good place to start is with the manufacturer's recommendations. These formulas and tips provide useful guidelines.
  • Inserts For Difficult Materials
    Economic efficiency is an important consideration when choosing tools for challenging metals.
Related Topics
Resources
