9/21/2018
Trunnion Machine Smooths Shop’s Workflow
This article looks at an automotive aftermarket supplier that consolidated its multi-machine process into a single machining cell.
Time in the cut is a universal measurement for any metalworking shop. The longer a machine tool is making chips, uninterrupted, the more productive that machine is.
This article, “Rotary Transfer Reduces Manufacturing Steps and Opens Opportunities,” looks at an automotive aftermarket supplier that consolidated its multi-machine process into a single machining cell. This move has opened up additional capacity for the shop to take on more work for its customers.
The new cell is built around an eight-station BTB rotary transfer machine that is sold and serviced by Gosiger High Volume. The machine uses a trunnion configuration, which allows access to both ends of a workpiece for simultaneous machining while it is gripped in the center by the trunnion.
Like all multi-spindles, with each index of the trunnion, a complete part is ejected. It’s a highly productive system and has allowed the shop, Tramec Sloan, to expand its capacity into other areas. Click here to read the full article.
RELATED CONTENT
  • Pins: The Alternative To Parallels
    These vise jaws use protruding, mechanical pins to repeatedly support workpieces either horizontally or at angles. They are said to allow quicker setups than conventional parallels.
  • A Study Of The Steady Rest
    When the length and stiffness of a workpiece make it difficult to machine without distorting or deflecting the part, many manufacturers turn to the steady rest as a workpiece support device. This is especially true for long axles, shafts and similar parts used in automotive or heavy equipment applications, and in oil drilling components. The most common application is to support a workpiece during turning or milling and, increasingly, during secondary operations such as ID drilling, boring and producing end face bolthole patterns.
  • Workholding In A Vacuum
    An aerospace machine shop meets a special need by using a vacuum chuck.
Resources
