Why are cutting tools coated? Most would say it is to protect the tool. That answer is true as far as it goes, but the function of the coating is more varied and more specific than that. In this video, I get to talk about coatings with Julius Schoop, Ph.D., machining expert with the Cincinnati-based manufacturing consulting firm TechSolve. (Actually, he is now formerly with TechSolve—he accepted a university professor position while this video was in production.)
In particular, Dr. Schoop and I focus on the difference between physical vapor deposition (PVD) and chemical vapor deposition (CVD) coatings. PVD is a line-of-sight process allowing for a thinner coating and therefore a sharper edge. CVD produces a thicker coating more effective as a thermal barrier.
The machining footage in this video shows the difference as we experiment with different coatings in both roughing and finishing passes in 4140 steel. Choosing the right coating for the cut can have a dramatic effect on the performance of the process.
Kyocera Turning Grade Provides Tough Cutting Edge
The Megacoat Tough coating combines a wear-resistant layer on the surface adhered to high-content CBN, which provides greater fracture resistance when encountering interruptions.
Cermet Turning Insert Maximizes Dimensional Accuracy
Walter’s cermet turning insert is designed to ensure dimensional accuracy, superior surface finish and reduced vibration.
Buying a Lathe: The Basics
