10/13/2018
Video: What Can Force Analysis Tell You About Your Machining Process?
See cuts and force profiles corresponding to tool failure, built-up edge and a tool that is too positive for the setup.
Connect at
TechSolve will be exhibiting new technology at IMTS 2020 in Chicago this September.
Plan to meet up with their team or get registered here!
I recently had the chance to work with TechSolve, the machining consulting firm based in Cincinnati, Ohio, on filming some really ugly machining passes.
The point was cutting force analysis. Watching poorly performing cuts while also seeing the corresponding cutting force profiles illustrates what force measurement can reveal about the process. In many cases, force monitoring is limited to the machine’s spindle-load monitor, but TechSolve can bring more than this. It can measure forces more specifically and directly using a three-component dynamometer.
Force analysis can be useful for diagnosing the challenges of an application involving a difficult workpiece material and/or an unstable process. To the knowledgeable observer, force profiles can reveal the problem areas in a process—the shortcomings to address to make the process consistent and reliable enough for unattended machining.
In this video of machining 4140 steel, watch the cuts and see the force profiles corresponding to (1) gradual tool failure, (2) cutting with a rake angle that is too highly positive for the process and (3) the development of a built-up edge.
RELATED CONTENT
  • Rolling Threads Has Advantages
    With macros and canned cycles resident in the CNC on most contemporary turning centers, single point turning of OD threads can seem like almost a default process decision. However, for numerous applications, OD thread rolling has inherent advantages as an alternative to cutting threads.
  • How One CNC Shop Effectively Machines Glass-Fiber-Filled Plastics
    You know how to machine metals, but what about plastic machining? More specifically, glass-fiber-reinforced plastic? This machine shop has it figured out.
  • Taking The Fear Out Of Hard Turning
    To make the transition to hard turning, you'll need to switch from carbide to CBN inserts, but that is easier (and more economical) than you might think. It's making the jump to much higher surface speeds that might scare you off. It needn't. Here's why.
Resources
