12/27/2018
What to Consider When Turning Exotic Materials
The properties that make exotic materials desirable for aerospace, energy and medical applications mean that machining them requires proper planning, equipment and strategies.
Exotic materials like heat-resistant superalloys and titanium alloys are becoming more in-demand, especially in industries like aerospace, energy and medical. But the properties that make them especially well-suited to these applications (including strength-to-weight ratio, strength and hardness retention at high temperatures, and corrosion resistance) also make them more difficult to machine. As the article “Turning Exotic Materials” describes, turning these materials is not impossible with proper planning, equipment and strategies.
Because the window for machining these materials is relatively small, it requires planning strategies in advance. This means establishing the best tool approach, cutting data and tool paths. Calculating spiral cutting length can also help predict and program when to index inserts.
These applications require dedicated tools with specific insert shapes and grades. The best tool is determined by a combination of lead/entering angle of the cutting edge, the stage of turning operation (roughing, semi-finishing or finishing), workpiece condition and the type of cut. Stable toolholding, a capable machine with rigid setup conditions, and optimized coolant application also help with machining exotic materials.
Read “Turning Exotic Materials” for all the details.
Hand holding a crystal ball
We’d rather send you $15 than rely on our crystal ball…
It’s Capital Spending Survey season and the manufacturing industry is counting on you to participate! Odds are that you received our 5-minute Metalworking survey from Modern Machine Shop in your mail or email. Fill it out and we’ll email you $15 to exchange for your choice of gift card or charitable donation. Are you in the U.S. and not sure you received the survey? Contact us to access it.
Help us inform the industry and everybody benefits.
RELATED CONTENT
  • Multitasking's "Big" Advantage
    As demonstrated at this Cincinnati-area shop, machines that both mill and turn shine brightest when workpieces are massive.
  • More Effective Camshaft Machining
    A leading manufacturer of high-performance valve train components installed a twin spindle/twin-turret lathe to bring camshaft machining work in-house. Here, the company explains how it has become more effective using its multifunction lathe to produce small batches of custom racing camshafts.
  • The Buzz about the B Axis
    The rotating milling head is a defining feature on a turn-mill machine designed for efficient production of complex parts in low volumes.
Related Topics
Resources
