Tormach's 1500MX CNC Mill
5 Stages of a Closed-Loop CNC Machining Cell
Controlling variability in a closed-loop manufacturing process requires inspection data collected before, during and immediately after machining — and a means to act on that data in real time. Here’s one system that accomplishes this.
The common thread that ties together any digital-first architecture for shopfloor automation is software that can leverage data from connected shopfloor devices. In this photo of a fully automated cell, the Renishaw Central software platform achieves end-to-end process control via multi-directional data flows between the software, a machine tool, a robot and a gaging system.
To create the Renishaw Central system, the company examined years of its own historical production data, using Microsoft’s Power BI data visualization tool to build dashboards and create custom reports of historical and real-time data from the company’s production equipment. In this image, the gaging machine is programmed to measure part features and, when a measurement departs from the nominal value for a given feature (indicating tool wear) the company’s Intelligent Process Control (IPC) system sends compensating tool offsets to the machine tool CNC. In this way, the system is able to transform connected data into actionable information. Here’s how it works:
  1. Incoming materials or workpieces from earlier stages are stored on racks alongside finished parts.
  2. Closed-loop CNC machining uses feedback from Renishaw Central to update tool offsets and variables, maintaining process control. This extends the usual functions of in-machine tool setting and spindle probes, which now also send data to Renishaw Central. This data can be compared and corroborated with data from shop-floor gages and CMMs.
  3. A part transfer robot automates the movement of workpieces between storage, the CNC machine, and a near-line gaging system, allowing the manufacturing cell to run unattended. The Central platform monitors the quality of parts and processes, halting operations if they go beyond set limits. This automation ensures consistent quality without the worry of producing uncontrolled scrap.
  4. A Renishaw Equator shopfloor gage delivers measurement and dimensional feedback to the Central platform, allowing for rapid quality control after machining and providing the data needed for process adjustments before machining additional workpieces.
  5. The Central dashboards offer different overviews of the manufacturing process, from tool setting and in-machine inspection, to Equator shop-floor checks and IPC configurations. This helps to ensure a closed-loop process and enhances confidence in automated settings.
The Automated Shop Conference
