Mill’s “Oil Shroud” Virtually Eliminates Dust in Graphite Machining
Amerimold 2017: EDM Network will exhibit the HM43GT graphite mill, which features an optional “oil shroud” that virtually eliminates the dust common to graphite milling.
El McKenzie, Managing Editor, Products Finishing magazine
EDM Network will exhibit the HM43GT graphite mill, which features an optional “oil shroud” that virtually eliminates the dust common to graphite milling. EDM-compatible oil captures the graphite dust, and then it is filtered through 2-30-micron cartridge filters. Vacuum compatibility is also available.
The HM43GT and two larger models, the HM65GT and HM86GT, all feature 30,000-rpm spindles with HSKE 32, 40 and 50 tapers, plus optional Blum laser diameter compensation and Fagor glass scales. In addition to graphite milling, the larger models can be equipped with 10- and 15-Kw motors to mill metals as hard as 63 HRC.
  • How to Start a Swiss Machining Department From Scratch
  • Choosing a Five-Axis Machine Tool With Automation in Mind
Meet us at booth 338190 - CHIRON Group
