Okuma
A few months ago during Westec, we had a chance to talk to applications engineer Bailey Stump with Marubeni-Citizen Cincom about new capabilities on its flagship Swiss-style lathe, the L20XII ATC (Automatic Tool Changer).
As highlighted in the video above, the ATC tooling with a fully programmable B-axis can be mounted on the gang tool post, enabling a total of 13 B-axis tools (12 ATC tools and one built into the tooling).
The ATC’S tool setting allows for several types of workpieces to be completed in a single setup and used in a wide range of applications — especially parts that require a lot of cross/end face machining. These can include difficult-to-machine components requiring secondary operations like finishing and deburring, components requiring multiple live tools, as well as rough and finish cuts that can be split between multiple tools.
Stump also says that having 13 total tools mounted to the b-axis opens up options for the manufacturing engineering team to get complex or difficult-to-machine parts off the machine complete, minimizing part handling.
Note the tool magazine in the back-left corner. According to Marubeni-Citizen Cincom, this 12-position carousel enters and exits the cutting room along the A5 axis and allows for a tool change in less than under 5 seconds.
  • 5 Tips for Running a Profitable Aerospace Shop
  • Inverting Turning and Five-Axis Milling at Famar
  • When Too Many Customers Spoil the Part
    Duo CNC used to take on as many customers as the shop could handle. But when growth stalled, a top-down audit by the company’s general manager revealed that its customer base was inhibiting growth — and causing the shop to be less efficient and productive.
Okuma
High Accuracy Linear Encoders
Okuma at IMTS 2024
