Weldon-Flat Tools in a Precision Toolholder
This system uses the standard Weldon flat so that end mills do not have to be modified for locking in place when a precision toolholder takes high-force cuts.
Systems for locking end mills in place within a shrink-fit or hydraulic expansion toolholder, so that there is no danger of the tool pulling out during high-force cuts using a toolholder of this type, often require the shank of the tool to be modified for clamping.
However, there is one standard class of tools that already has a shank modified for clamping: tools with Weldon flats.
Schunk recently introduced a system that makes use of the Weldon flat for clamping during high-force milling with a precision holder. The system, seen here as it was displayed at this year’s IMTS, is based on the company’s Tendo line of hydraulic-expansion toolholders. As seen in this model, a metal sleeve holds the tool, clamping on the Weldon flat. That sleeve then provides the surface for the screw that locks the tool in the holder for the high-force milling typical of aerospace materials such as titanium and Inconel.
Making the Most of Mixed Toolholder Assemblies
While nearly all ER systems will have cross compatibility, they’ll have small differences across manufacturers that make their implementation at the shop level not as standard.
Rego-Fix Toolholding System Reduces Coolant Consumption
