In Machine Tool Research, Learn to Compare and Contrast
A frequent Techspex user shares how the database enables him to more easily gather competitive quotes for machine tool acquisitions.
In preparation for February’s edition of Machine/Shop, I checked in with some of the “power users” among those registered to access Techspex, the free online machine tool database. It’s interesting to learn about how different users approach the database tools for different needs. After all, Techspex users range across end markets, from aerospace to medical, from energy to automotive. They also vary widely in size and scope, including job shops of all sizes, as well as big manufacturers like General Electric, Boeing and Nissan North America.
Mirko Dakic, for example, is a capital planner for Magna Powertrain, a global automotive manufacturer, assisting its North American divisions in capital investment. He explains how he uses Techspex to help him do his job: “As capital planner, I use Techspex to cross-reference and learn about different machine brands and models capable of the same job. In order to gather three competitive quotes, I use the list of machine tool builders along with the list of current and previous models to find possible alternative suppliers.”
Mr. Dakic describes two processes that make Techspex a potentially useful tool for research prior to acquiring a new machine, no matter the size of the shop: cross-referencing machine models and gathering competitive quotes.
As he suggests, it’s important to be able to compare models that are capable of similar work when looking for a new machine. While some OEM websites can show specifications of their own machines in a comparative chart, it can be difficult to do the same among machine makers. Techspex enables users to compare machine tools side by side, across brands. First, they can select a machine type (turning, milling, grinding or EDM). This provides a set of fields enabling a query of machines that align with specific specification ranges (chuck or bar diameters, horsepower, turning length, number of spindles and direction, for example). Users can also narrow the query to include only specific manufacturers. In the results list, they can mark models and generate a spreadsheet that compares them spec-for-spec.
While cross-referencing machine data is useful for narrowing a new machine tool search, moving to acquire a machine requires additional information. As Mr. Dakic explains, it is useful to get multiple quotes to further refine the potential choices by cost. In any Techspex machine model listing, users can click the “RFQ” button to generate a detailed form that requests quotes from relevant machine suppliers and distributors.
Techspex users get free access to these tools and more by registering at techspex.com.
This blog post originally appeared at techspex.com.
Three-Axis Bridge Mill Opens New Doors for Construction OEM
Different industries often require different machining priorities, a truism recently demonstrated by Barbco, an OEM of heavy-duty boring equipment that opened up new design possibilities by pivoting toward rigid, less complex machining centers.
