turning and grinding workholding from SMW Autoblok
Updated Published
When To Use A Collet Chuck
Michael Minton and Michael Sullivan
Collection of collets
Photo Credit: Getty Images
The three-jaw powered chuck is the standard workholding device for most CNC lathe users. This type of chuck is versatile enough to be used in a wide range of turning applications. However, it's not the best chuck for all jobs. The collet chuck is an alternate workholding device that, like the jaw chuck, also uses mechanical force to hold the part being turned. While a collet chuck lacks the capacity for the same wide range of workpiece sizes that a jaw chuck can accommodate, it offers advantages related to speed, accuracy and productivity that may be crucial for certain jobs.
Several factors figure into the determination of which type of chuck would work better. When evaluating a collet chuck versus a jaw chuck for a given lathe application, take all of the following factors into account.
Spindle Load Capacity
The lathe spindle has a maximum allowable weight based on bearing load capacity. If the combination of the chuck and the work accounts for too much weight, the bearings may be overloaded. In applications where there is a danger of exceeding this limit, this very danger may dictate the choice of workholding. Jaw chucks tend to be more massive than comparable collet chucks, making the collet chuck an appropriate choice where weight control is needed
Spindle Speed
A collet chuck tends to be the better choice for turning at particularly high levels of spindle rpm. There are two reasons for this.
One reason relates to the mass of the chuck. Given the same spindle horsepower driving a jaw chuck and a collet chuck, the more massive jaw chuck would take longer to accelerate up to speed. The acceleration time would extend cycle time and reduce productivity.
Another reason relates to centrifugal force, which becomes a significant concern at high speeds because it increases as the square of rpm. For example, doubling the spindle speed causes centrifugal force to quadruple. This force pulls chuck jaws out from the center and tends to reduce clamping force. But with a collet chuck, centrifugal force does not have a significant effect. Therefore, clamping force is more constant across the speed range.
Wet carbide mill and collet chuck in vertical cnc milling machine
Operation To Be Performed
A collet chuck applies clamping force all around the circumference of the part instead of just at select contact areas. The result is tight concentricity. This can be particularly significant for second-operation work where accuracy relative to the first operation is a concern. Even when a jaw chuck is used for the first operation, a collet chuck may be used for the second operation because of its precision clamping. A jaw chuck with bored soft jaws repeats within 0.0006 to 0.0012 inch TIR. A collet chuck typically provides repeatability of 0.0005 inch TIR or better. The collet chuck can also be adjusted for concentricity during installation to further improve secondary operation accuracy.
Workpiece Dimensions
Collet chucks are best suited to workpieces smaller than 3 inches in diameter.
A collet chuck may also impose a limitation on the workpiece length. Specifically, a collet chuck limits the machine's range of axial (Z-axis) travel, because its length is longer than that of a jaw chuck. When the machining length of a workpiece is so long that just about all of the available travel of the machine is needed to cut it, then this requirement will probably dictate the use of a jaw chuck.
Lot Size
Very large and very small lot sizes both help make the case for a collet chuck.
Where there are small lot sizes and lots of them, the collet chuck's advantage relates to changeover time. Swapping jaws takes around 15 to 20 minutes for a standard jaw chuck or 1 minute on a jaw chuck specially designed for quick change, but the collet in a quick-change collet chuck can be changed in 15 to 20 seconds. The time savings add up where changeovers are frequent.
Similar time savings related to clamping add up where lot sizes are large. A collet chuck takes less time to open and close than a jaw chuck, shaving cycle time by reducing the non-cutting time from one piece to the next.
Workpiece Size Range
Part of the reason a collet chuck opens and closes more quickly is that its actuation stroke is shorter. Compared to a jaw chuck, a collet chuck is more limited in the range of workpiece sizes it can accommodate.
Collet chucks essentially trade flexibility for speed. If part size is consistent, a collet chuck is faster. But where workpieces vary significantly in size, it may take a jaw chuck to accommodate the complete range of work.
Types Of Materials
For hot rolled steel, castings, forgings and extrusions, standard jaw chucks tend to work better because of the diameter variations inherent in all of these types of parts. On the other hand, cold rolled material tends to be more consistent in size and therefore better suited to collet chucks.
However, the absence of any diameter measurement is not necessarily an obstacle to using a collet chuck. Collets designed for non-round cross sections can be provided for extruded bars that are made to custom shapes.
About the author: Michael Minton and Michael Sullivan work for ATS Workholding of Anaheim, California. Mr. Minton is eastern regional sales manager. Mr. Sullivan is vice president.
Collet Chuck Advantages
  • Light weight
  • Fast acceleration
  • Less affected by centrifugal force
  • Tight concentricity
  • Fast clamping
  • Fast collet change for part changeover
High Accuracy Linear Encoders
Gravotech
Gardner Business Intelligence
The Automated Shop Conference
Automotive dies and die inserts are often complex, one-off parts with little room for error. Integrity Tool's investments in modular workholding tools and 3D optical scanning have allowed the company to create niche capabilities for its CNC machined parts.
Workholding
Automation
Simple Workholding for Robotic Automation
Workholding
Toolholders
Collet Chuck System Helps Produce AR Parts Efficiently
A collet chuck system from Horn USA Inc. helped firearm parts manufacturer Manufacturing Partners Inc. hit is productivity targets.
Large Part Machining
