End Mill Comparisons in CFRP, Part 2 - Diamond-Coated Tool
Video shows the performance of coated carbide, diamond-coated, PCD and veined PCD tools in carbon fiber reinforced plastic. Part two in a four-part series.
View MorePhillips Corporation
Smith MegaDiamond Inc. and Star Cutter Company compared the performance of various end mills in carbon fiber reinforced plastic (CFRP). The tools tested included a coated carbide end mill, a diamond-coated end mill, a conventional PCD end mill with straight flutes, and a “veined” PCD end mll featuring a vein of PCD within a helical slot in a carbide tool body.
The table below summarizes the test parameters. Shown here is the video of a 10-degree helical diamond-coated tool. Jeff Michael, engineering manager for Star Cutter, comments, “Again, the sound is pretty good with this cutter, but uncut fibers appear immediately. This is because a tool’s coating tends to give it a more rounded cutting edge, making it more difficulty to cut the fibers cleanly off.”
To see the next video in this testing, click here.
Tool Type |
Ø .500 in. |
Solid Carbide |
CVD Diamond |
PCD |
Veined PCD |
Flute angle |
30° helical |
10° helical |
7° skew |
30° helical |
Spindle speed (rpm) |
3,000 |
4,600 |
12,000 |
18,000 |
Chip load (in./tooth) |
0.0035 |
0.0035 |
0.001 |
0.0065 |
Machine advance (in./min.) |
42 |
64 |
36 |
470 |
Radial depth (in.) |
.050 |
.050 |
.050 |
.050 |
Cutting speeds and feed rates were recommended parameters from each tool’s manufacturer.
Editor’s note: To read the next part in the series, click here.
