CERATIZIT
End Mill Comparisons in CFRP, Part 4 - Veined PCD Tool
Video shows the performance of coated carbide, diamond-coated, PCD and veined PCD tools in carbon fiber reinforced plastic. Part four in a four-part series.
Loading the player ...
Smith MegaDiamond Inc. and Star Cutter Company compared the performance of various end mills in carbon fiber reinforced plastic (CFRP). The tools tested included a coated carbide end mill, a diamond-coated end mill, a conventional PCD end mill with straight flutes, and a “veined” PCD end mll featuring a vein of PCD within a helical slot in a carbide tool body.
The table below summarizes the test parameters. Shown here is the video of a 30-degree helical veined PCD tool. Jeff Michael, engineering manager for Star Cutter, comments, “The sound is great. The corners are sharp, and the uncut fibers are minimal because of the shearing effect the geometry has. The last full cut was just to prove out the robustness of the tool, and would not be recommended in production. If you look closely, you can actually see the cutter glow. This does not damage the cutter. Other end mills broke when we attempted to run them at these parameters.”
Tool Type
Ø .500 in.
Solid Carbide
CVD Diamond
PCD
Veined PCD
Flute angle
30° helical
10° helical
7° skew
30° helical
Spindle speed (rpm)
3,000
4,600
12,000
18,000
Chip load (in./tooth)
0.0035
0.0035
0.001
0.0065
Machine advance (in./min.)
42
64
36
470
Radial depth (in.)
.050
.050
.050
.050
Cutting speeds and feed rates were recommended parameters from each tool’s manufacturer.
  • Aerospace Shop Thrives with Five-Axis, AI and a New ERP
    Within three years, MSP Manufacturing has grown from only having three-axis mills to being five-axis capable with cobots, AI-powered programming and an overhauled ERP. What kind of benefits do these capabilities bring? Find out in our coverage of MSP Manufacturing.
  • Roughing First: New Strategies for Blisk Machining
    Aerospace shops looking to cut cycle time and tool wear on integrally bladed rotors often focus on finishing. But rethinking the roughing stage can increase how much material can be safely removed while accelerating throughput.
  • Achieving Large Cycle Time Savings on Large-Format Parts
    Aero-Tech Engineering sought a faster gantry mill to handle a growing queue of structural aerospace parts. But this machine proved even more productive than expected — and better able to handle the additional jobs its presence won for the shop.
Sumitomo
CERATIZIT
Cogsdill single pass deburring at the spindle!
Ingersoll Cutting Tools
Horn USA
MaxValue
Watch Video
Mikron Multistar neXT
Sumitomo
