EDM Brand Features New Digital Power Manager
Global EDM offers four machines from its Excetek EDM brand, including three from the new WGPlus series.
Global EDM offers four machines from its Excetek EDM brand, including three from the new WGPlus series. These machines include the W400GPlus, W500GPlus with rotary table, W650GPlus and ED400C die sinker.
The Excetek WGPlus series features a new digital power manager for improved cutting and accuracy. The machines are equipped with HP AVR Circuit to promote improved accuracy for multiple parts. Additionally, the machines feature two options for cutting surface roughness: WGPlus/SKD-11/Ra 0.3 micron; and WGPlus/Tungsten Carbide/Ra 0.1 micron.
The new WGPLUS builds on the popularity of the base WG series design. That series is known for its solid design and construction; electrolysis-free machining; accuracies and finishes ranging to Ra 0.3 micron; and easy-to-use Windows Controls using a 15" touch screen display.
  • 10 Things to Know About Creep-Feed Grinding
  • Choosing a Five-Axis Machine Tool With Automation in Mind
