A Square Hole for a Square Peg
Putting square and rectangular boxes into wedge-shaped slots in a vending system isn’t the best use of the space. A tambour-style system with rectangular columns and adjustable shelving creates slots that better accommodate items with their packaging.
This interior shot of AutoCrib’s TX750 tool vending system shows its vertical columns of adjustable shelves. To the left, you can see the inside of the system’s rolling dual-tambour door, capable of opening 2" to 60" to correspond with the selected bin.
Many industrial vending systems on the market today are based on pie-like trays divided into wedges. An operator calls up a tool or other expendable, and round carousels rotate until the appropriate wedge faces out. The operator can then open the door and remove the drill, insert or whatever it may be.
The system has its advantages, but according to Stephen Pixley, founder of AutoCrib, the wedge-shaped spaces also pose a dilemma. “Things come in rectangular boxes,” he points out, which means that in stocking the wedges, companies must waste either time (unpacking the boxes) or space (storing a square or rectangular box in a wedge-shaped hole).
Rather than pie-shaped trays system, AutoCrib’s TX750 vending system uses a carousel with slots more accommodating to box-shaped contents. The vending system features columns with adjustable shelving to accommodate boxes—as well as other objects of varying shapes and sizes. The slots can be adjusted to hold everything from a tiny insert to a 2-foot-plus fluorescent light bulb. The customizability of the slots reduces vertical bin height waste and increases the capacity that can be stored within a compact footprint. As many as 900 bins can be packed into the unit, which occupies 9.8 square feet of floor space.
The TX750 has another advantage that enables it to provide just the right product at the right time: rolling dual-tambour doors. When an operator calls for a product in a particular slot, the two doors rotate to the appropriate shelf and open only that slot. The doors can open to anywhere from 2" to 60" in half-inch increments.
The vending system is controlled by AutoCrib’s user interface with 19" touchscreen, and a native bin assignment process simplifies stocking the unit on the fly. Operators can identify themselves with an ID card or a fingerprint and search the system to retrieve items.
Buying a Lathe: The Basics
