Horn USA
Ballnose Inserts Feature PCD Tips
Dapra precision-ground ballnose inserts with PCD tips are diamond-tipped for milling soft, nonferrous materials such as aluminum and graphite.
Dapra Corporation’s precision-ground ballnose inserts with PCD tips are diamond-tipped for milling soft, nonferrous materials such as aluminum and graphite. According to the company, the inserts increase wear resistance and have an expected life as much as 100 times longer than carbide-coated inserts. The PCD-tipped inserts are precision ground to provide a sharp, accurate cutting radius. Available with 3/8", 1/2" and 3/4" diameters, the inserts are designed for use with the company’s standard steel, carbide-core and carbide-shank cutter bodies.
  • A New Milling 101: Milling Forces and Formulas
  • New Modular Tool Options for Small Spindle Milling
  • Choosing Your Carbide Grade: A Guide
Sumitomo
Iscar
Horn USA
IMCO
GWS Tool Group
SGS
Sumitomo
