Band Saw Performs Stable, Durable Metalcutting
The Trajan 20 heavy-duty band saw from Sawblade.com is designed for efficiency and durability.
The Trajan 20 heavy-duty band saw from Sawblade.com is designed for efficiency and durability. The semi-automatic machine includes a sizeable working platform and a rear roller table. The band saw’s hydraulic saw arm lifting system and a gear-drive system equipped with a variable step pulley enable making cuts quickly and at the appropriate speed. A buffer spring and enlarged hydraulic cylinder contribute to the machine’s durability and stability. Its tungsten blade guides reduce blade vibration and increase cutting accuracy. A coolant system for wet cutting ensures that the saw blade and material stay at the proper temperatures. With a 13" × 18" capacity and a 0- to 60-degree cutting angle, the Trajan 20 band saw can handle a range of applications.
Meet us at booth 338190 - CHIRON Group
