Big Kaiser's Mini Indexable Boring Bar Meets Medical, Aerospace Needs
The 4-mm Mini indexable boring bar from Big Kaiser is designed to be ideal for small-component machining.
The 4-mm Mini indexable boring bar from Big Kaiser is designed to be ideal for small-component machining, meeting what the company sees as increasing demand in the medical and aerospace industries for boring of small medical implant devices and micro components.
The main advantage of this product, according to Big Kiaser, is the cost savings of replacing just the indexable insert in production versus replacing the entire bar (where the cutting edge is integral to it). The inserts can be exchanged without disturbing the overall geometry of the tool, maintaining consistent cutting results.
The indexable inserts feature sharp cutting edges that help lower cutting forces and vibration. Inserts with cutting geometry specially developed for carbon steel, alloyed steel and aluminum are also available.
Custom PCD Tools Extend Shop’s Tool Life Upward of Ten Times
Adopting PCD tooling has extended FT Precision’s tool life from days to months — and the test drill is still going strong.
Tungaloy Expands Drill System With Drill Sleeves
Adding drill sleeves to the standard lineup enhances drilling productivity of Swiss-type sliding-head automatic lathes.
Walter Extends Line of Precision Boring Tools
The new boring tools employ modular components such as cartridge holders and extensions, which are matched to the system, utilize an extensive range of indexable inserts suited for precision boring and can be used for all material groups.
