Clamping Tool Designed to Steady Small Parts
Strong Hand Tools’ Grasshopper Clamping Tool is designed to steady small parts such as bolts, nuts, tabs and thin metal plates for tack welding at odd angles with full welding clearance.
Strong Hand Tools’ Grasshopper Clamping Tool is designed to steady small parts such as bolts, nuts, tabs and thin metal plates for tack welding at odd angles with full welding clearance. The brass tips of the clamping tool rest against small, thin metal or stainless steel parts. The Grasshopper can be adjusted by sliding the upper arm or leg base against the weighted body to provide the proper stability and balance in each tack welding setup. The Pro Model Grasshopper, part No. AGH130P, includes three brass tips, a grounding ribbon, and a spring clip attachment for holding small rods or steadying thin metal plates.
